network connections active show-clients
Show a count of the active connections by client
The network connections active show-clients command displays information about client connections, including the client's IP address and the number of client connections.
The results of this command set are refreshed independently every 30 seconds and might not reflect the immediate state of the system. |
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-node {<nodename>|local}]- Node-
Use this parameter to display information only about the connections on the node you specify.
 [-vserver <vserver>]- Vserver-
This parameter is used by the system to break down the output per vserver.
 [-remote-address <Remote IP>]- Remote IP Address-
Use this parameter to display information only about the connections that use the remote IP address you specify.
 [-count <integer>]- Client Count-
Use this parameter to only clients with the number of active client connections you specify.
The following example displays information about active client connections:
cluster1::> network connections active show-clients
Node    Vserver Name    Client IP Address     Count
node0   vs1             192.0.2.253                1
        vs2             192.0.2.252                2
        vs3             192.0.2.251                5
node1   vs1             192.0.2.250                1
        vs2             192.0.2.252                3
        vs2             customer.example.com       4
