vserver vscan connection-status show-connected
Display connection status of connected Vscan servers
The vserver vscan connection-status show-connected
command displays connection status information of the connected external virus-scanning servers, or "Vscan servers". If you do not specify any parameters, the command displays the following information for all Vscan servers:
Vserver name
Node name
Vscan server
Vscan server vendor
Privileged user
You can specify the -fields
parameter to specify which fields of information to display. In addition to the fields above, you can display the following fields:
Server type
Vscan server version
Vscan server connected since
Vserver LIF used for connection
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you specify this parameter, the command displays information only about the Vscan servers attached to the specified node.
[-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the Vscan servers for the specified Vserver.
[-server <IP Address>]
- Server-
If you specify this parameter, the command displays information only about the Vscan server that you specify.
[-vendor <text>]
- Vscan Server Vendor-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified vendor.
[-version <text>]
- Vscan Server Version-
If you specify this parameter, the command displays information only about the Vscan servers that are running scan-engine of the specified version.
[-privileged-user <text>]
- Privileged User Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that are connected to clustered Data ONTAP using the specified privileged user.
[-connected-since <MM/DD/YYYY HH:MM:SS>]
- Time When Vscan Server Was Connected-
If you specify this parameter, the command displays information only about the Vscan servers that have been connected since the specified time.
[-server-type <Server type>]
- Server Type-
If you specify this parameter, the command displays information only about the Vscan servers that have the specified server type.
[-lif <IP Address>]
- Vserver LIF Used for Connection-
If you specify this parameter, the command displays information only about the Vscan servers that have used the specified IP address for connecting to clustered Data ONTAP.
The following example displays connection-status information about all connected Vscan servers.
cluster1::> vserver vscan connection-status show-connected Privileged Vserver Node Server Vendor User ------------- ----------------- ---------------- ------------- --------------- vs1 Cluster-01 1.1.1.1 ABC cifs\u2 vs1 Cluster-01 2.2.2.2 XYZ cifs\u2 2 entries were displayed.
The following example displays detailed connection-status information about connected Vscan servers which are running XYZ scan-engine.
cluster1::> vserver vscan connection-status show-connected -instance -vendor XYZ Node: Cluster-01 Vserver: vs1 Server: 2.2.2.2 Vscanner Vendor: XYZ Vscanner Version: 1.12 Privileged User Used for Connection: cifs\u2 Time When Vscanner Was Connected: 6/3/2013 08:44:21 Server Type: primary Vserver LIF Used for Connection: 10.238.41.223
