vserver peer show
Display Vserver peer relationships
The vserver peer show
command displays the following information about Vserver peer relationships:
Local Vserver name
Peer Vserver name
Local Vserver UUID
Peer Vserver UUID
Peer cluster name
State of the peering relationship
Applications
Remote Vserver name
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Local Vserver Name-
If this parameter is specified, the command displays relationships that match the specified local Vserver.
[-peer-vserver <text>]
- Peer Vserver Name-
If this parameter is specified, the command displays relationships that match the specified peer Vserver.
[-peer-state {peered|pending|initializing|initiated|rejected|suspended|deleted}]
- Peering State-
If this parameter is specified, the command displays relationships that match the specified peer state.
[-applications {snapmirror|file-copy|lun-copy|flexcache}]
- Peering Applications-
If this parameter is specified, the command displays relationships that have the specified applications.
[-peer-cluster <text>]
- Peer Cluster Name-
If this parameter is specified, the command displays relationships that have the specified peer cluster name.
[-peer-vserver-uuid <UUID>]
- Peer Vserver UUID-
If this parameter is specified, the command displays relationships that match the specified peer Vserver UUID.
[-vserver-uuid <UUID>]
- Local Vserver UUID-
If this parameter is specified, the command displays relationships that match the specified local Vserver UUID.
[-remote-vserver-name <text>]
- Remote Vserver Name-
If this parameter is specified, the command displays relationships that match the specified remote Vserver.
The following examples illustrate how to display Vserver peer relationships. + Cluster administrator:
cluster1::> vserver peer show Peer Peer Peering Remote Vserver Vserver State Peer Cluster Applications Vserver ----------- ----------- ------------ ----------------- -------------- --------- lvs1.example.com lvs2.example.com peered cluster1 snapmirror lvs2.example.com lvs1.example.com pvs1.example.com peered cluster2 snapmirror pvs1.example.com lvs2.example.com lvs1.example.com peered cluster1 snapmirror lvs1.example.com lvs3.example.com pvs1_cluster3.example.com peered cluster3 snapmirror pvs1.example.com lvs1.example.com lvs1_cluster4.example.com peered cluster4 snapmirror lvs1.example.com 5 entries were displayed.
Vserver administrator:
vs11.example.com::> vserver peer show Peer Peer Peering Remote Vserver Vserver State Applications Vserver ----------- ----------- ------------ --------------------- ---------- vs11.example.com pvs21.example.com peered snapmirror pvs21.example.com vs11.example.com vs12.example.com peered file-copy, snapmirror vs12.example.com 2 entries were displayed.
