vserver cifs branchcache hash-create
Force CIFS BranchCache hash generation for the specified path or file
The vserver cifs branchcache hash-create
command causes the BranchCache service to compute hashes for a single file, for a directory, or for all the files in a directory structure if you specify the -recurse
option.
-vserver <vserver name>
- Vserver-
This parameter specifies the CIFS-enabled Vserver on which the hash is computed.
-path <text>
- Path of File or Directory to Hash-
This parameter specifies the path of the directory or file for which hashes are to be computed. If a file is specified, the hashes are computed on the whole file. If a directory is specified, hashes are computed on all files within the directory.
-recurse {true|false}
- Process All Files in the Directory Recursively-
If this option is set to true and the
-path
parameter specifies a directory, hashes are computed recursively for all directories in the path.
The following example creates hashes for the file "report.doc":
cluster1::> vserver cifs branchcache hash-create -vserver vs1 -path /repository/report.doc -recurse false
The following example creates hashes for all the files in the directory "repository":
cluster1::> vserver cifs branchcache hash-create -vserver vs1 -path /repository -recurse false
The following example recursively creates hashes for all the files and directories inside the directory "documents":
cluster1::> vserver cifs branchcache hash-create -vserver vs1 -path /documents -recurse true
