ONTAP commands
system node image modify
Modify software image configuration
The system node image modify command sets the default software image on a specified node. The default software image is the image that is run when the node is started. A node holds two software images; when you set one as the default image, the other image is automatically unset as the default. Conversely, if you unset a software image as the default, the other image is automatically set as the default.
-node {<nodename>|local} - Node (privilege: advanced)
This specifies the node on which the software image is located.
-image {image1|image2|remote} - Image Name (privilege: advanced)
This specifies the software image that is to be set or unset as the default.
[-isdefault {true|false}] - Is Default Image (privilege: advanced)
This optionally specifies whether the specified image is the default.
The following example sets the software image named image2 as the default image on a node named node0.
node::> system node image modify -node node0 -image image2 -isdefault true
Default Image Changed.
