volume file show-filehandle
Show the file handle of a file
This command requires a path to a file in a volume and displays the file handle information described below:
Vserver name
Path to the file
File handle flags
Snapshot ID of the file (snapid)
File ID
File handle generation number
File system ID (fsid)
Master data set ID (msid)
Data set ID (dsid)
If not logged in as a Vserver administrator, the command also requires a Vserver name.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver Managing Volume (privilege: advanced)
This specifies the Vserver where the file resides.
- [-path <text>]- Path to File (privilege: advanced)
This specifies the path to the file.
The following example displays the file handle information of a file named file1.txt in the volume /vol/vol1 .
cluster1::> volume file show-filehandle -vserver vs0 -path /vol/vol1/file1.txt
             Vserver                    Path
             vs0                         /vol/vol1/file1.txt
flags   snapid  fileid     generation  fsid        msid          dsid
             0x0     0       0x60       0x206b6     0x402       0x80000402    0x402
 PDFs
PDFs
