system node root-mount create
Create a mount from one node to another node’s root volume.
The system node root-mount create
command produces a root-mount from one node in the cluster to another node’s root volume. The root-mount is marked for immediate creation by a background task. Use the system node root-mount show command to view the current status of root-mount or verify task completion.
-node <nodename>
- Owner of the Root-mount-
The node name where the root-mount will be created.
-root-node <nodename>
- Root-mount Destination Node-
The node name that the root-mount will access.
The following example shows the creation of a root-mount from cluster1::nodeA
to cluster1::nodeB
and the verification of the successful completion.
cluster1::> system node root-mount show This table is currently empty. cluster1::> system node root-mount create -node nodeA -root-node nodeB cluster1::> system node root-mount show Node Root Node State Last Error ----------------- ----------------- ----------- ------------------------------- nodeA nodeB ready
