lun import resume
Resume the import for the specified LUN
Resumes the data import to a specified LUN.
The import starts from the last checkpoint taken before you paused the data import.
If you want to resume the data import from the beginning, use the lun import stop command. Then use the lun import start command.
-vserver <Vserver Name> - Vserver Name
Specifies the Vserver that contains the LUN you want to resume the data import to.
-path <path> - LUN Path
Specifies the path of the LUN that you want to resume the data import to. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
cluster1::> lun import resume -vserver vs1 -path /vol/vol2/lun2
Resumes the data import to lun2 at the path /vol/vol2/lun2
