storage aggregate efficiency cross-volume-dedupe show
Display aggregate cross volume deduplication efficiency details
The storage aggregate efficiency cross-volume-dedupe show
command displays information in detail about the different storage efficiency of all the aggregates.If no parameters are specified, the command displays the following information for all aggregates:
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-aggregate <aggregate name>]
- Aggregate-
Displays the aggregate name. If this parameter is specified, the command displays detailed information about the storage efficiency of the specified aggregate.
[-node {<nodename>|local}]
- Node-
Displays the node which owns the aggregate. If this parameter is specified, the command displays storage efficiency information only about the aggregates that are located on the specified node.
[-background-progress <text>]
- Progress-
Displays the information for the aggregates that match the specified progress.
[-background-op-status <text>]
- Operation Status-
Displays the information for the aggregates that match the specified operation status.
[-background-last-op-state <text>]
- Last Operation State-
Displays the information for the aggregates that match the specified last operation state.
[-background-last-success-op-begin <Date>]
- Last Success Operation Begin Time-
Displays the information for the aggregates that match the specified last successful operation begin time.
[-background-last-success-op-end <Date>]
- Last Success Operation End Time-
Displays the information for the aggregates that match the specified last successful operation end time.
[-background-last-op-begin <Date>]
- Last Operation Begin Time-
Displays the information for the aggregates that match the specified last operation begin time.
[-background-last-op-end <Date>]
- Last Operation End Time-
Displays the information for the aggregates that match the specified last operation end time.
[-background-last-op-error <text>]
- Last Operation Error-
Displays the information for the aggregates that match the specified last operation error.
[-background-stage <text>]
- Stage-
Displays the information for the aggregates that match the specified stage.
[-background-checkpoint-time <Date>]
- Checkpoint Time-
Displays the information for the aggregates that match the specified checkpoint time.
[-background-checkpoint-op-type <text>]
- Checkpoint Operation Type-
Displays the information for the aggregates that match the specified checkpoint operation type.
[-background-checkpoint-stage <text>]
- Checkpoint Stage-
Displays the information for the aggregates that match the specified checkpoint stage.
[-background-dedupe {true|false}]
- Background State-
Displays the information for the aggregates that match the specified cross volume background dedupe state.
[-inline-dedupe {true|false}]
- Inline State-
Displays the information for the aggregates that match the specified cross volume inline dedupe state.
[-dedupe-savings {true|false}]
- Has Cross Volume Deduplication Savings-
Displays the information for the aggregates that has some savings from cross volume deduplication.
The following example displays information about all aggregates that are owned by nodes in the local cluster:
cluster:::> storage aggregate efficiency cross-volume-dedupe show Aggregate: aggr0 Node: vivek6-vsim2 Has Cross Volume Deduplication Savings: false --------:Cross Volume Background Deduplication Status:-------- State: false Progress: - Operation Status: Idle Last Operation State: Success Last Success Operation Begin Time: - Last Success Operation End Time: - Last Operation Begin Time: - Last Operation End Time: - Last Operation Error: Operation succeeded Stage: - Checkpoint Time: - Checkpoint Operation Type: - Checkpoint Stage: - -----------:Cross Volume Inline Deduplication Status:--------- State: false Aggregate: aggr1 Node: vivek6-vsim2 Has Cross Volume Deduplication Savings: true --------:Cross Volume Background Deduplication Status:-------- State: true Progress: - Operation Status: Idle Last Operation State: Success Last Success Operation Begin Time: Wed Aug 30 06:31:50 2017 Last Success Operation End Time: Wed Aug 30 06:31:50 2017 Last Operation Begin Time: Wed Aug 30 06:31:50 2017 Last Operation End Time: Wed Aug 30 06:31:50 2017 Last Operation Error: Operation succeeded Stage: Cross volume sharing Done Checkpoint Time: - Checkpoint Operation Type: - Checkpoint Stage: - -----------:Cross Volume Inline Deduplication Status:--------- State: true 2 entries were displayed.
