ONTAP commands
vserver cifs home-directory show
Display home directory configurations
The vserver cifs home-directory show command displays the CIFS home directory configuration for one or more Vservers.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver>] - Vserver
If you specify this parameter, the command displays CIFS home directory configuration for the specified Vserver.
[-is-home-dirs-access-for-admin-enabled {true|false}] - Is Home Directory Access for Admin Enabled
If you specify this parameter, the command displays home directory configuration for CIFS servers that have the specified setting.
[-is-home-dirs-access-for-public-enabled {true|false}] - Is Home Directory Access for Public Enabled (privilege: advanced)
The following example lists the CIFS home directory configuration for a Vserver on the cluster.
cluster1::> vserver cifs home-directory show -vserver vs1
Vserver: vs1
Is Home Directory Access for Admin Enabled: true
