vserver cifs home-directory show
Display home directory configurations
The vserver cifs home-directory show
command displays the CIFS home directory configuration for one or more Vservers.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver>]
- Vserver-
If you specify this parameter, the command displays CIFS home directory configuration for the specified Vserver.
[-is-home-dirs-access-for-admin-enabled {true|false}]
- Is Home Directory Access for Admin Enabled-
If you specify this parameter, the command displays home directory configuration for CIFS servers that have the specified setting.
[-is-home-dirs-access-for-public-enabled {true|false}]
- Is Home Directory Access for Public Enabled (privilege: advanced)-
The following example lists the CIFS home directory configuration for a Vserver on the cluster.
cluster1::> vserver cifs home-directory show -vserver vs1 Vserver: vs1 Is Home Directory Access for Admin Enabled: true
At the advanced privilege level or above, the output displays the information below:
cluster1::*> vserver cifs options show Vserver: vs1 Is Home Directory Access for Admin Enabled: true Is Home Directory Access for Public Enabled: false
