volume reallocation show
Show reallocate job status
Displays the status of a reallocation scan, including the state, schedule, interval, optimization, and log files. If you do not specify the path for a particular reallocation scan, then the command displays all the reallocation scans.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-v ]
Specify this parameter to display the output in a verbose format.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver
Specify this parameter to display reallocation scans that match the Vserver that you specify.
- [-path <text>]- Path
Specify this parameter to display reallocation scans that match the path that you specify.
- [-t, -threshold <integer>]- Threshold
Specify this parameter to display reallocation scans that match the threshold that you specify.
- [-id <integer>]- Job ID
Specify this parameter to display reallocation scans that match the reallocation job ID that you specify.
- [-description <text>]- Job Description
Specify this parameter to display reallocation scans that match the text description that you specify.
- [-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}]- Job State
Specify this parameter to display reallocation jobs that match the state that you specify.
- [-progress <text>]- Execution Progress
Specify this parameter to list the running reallocation jobs whose progress indicator matches the text that you provide. For example, if you specify "Starting …" as the text string for the progress option, then the system lists all of the jobs that are starting.
- [-schedule <job_schedule>]- Schedule Name
Specify this parameter to display reallocation scans that match the schedule name that you specify. If you want a list of all job schedules, use the job schedule show command.
- [-global-status <text>]- Global State of Scans
Specify this parameter to indicate if reallocation scans are on or off globally. You must type either of the following text strings: -
"Reallocation scans are on"
"Reallocation scans are off"
cluster1::> volume reallocation show Vserver Description Schedule State ------- ----------- -------- ----- Reallocation scans are on vs0 /vol/vol2,space-optimized reallocate_1d Queued
Displays the Vserver, description, schedule, and state for the reallocation scans on the local node.
 PDFs
PDFs
