Command reference
volume reallocation show
Show reallocate job status
Displays the status of a reallocation scan, including the state, schedule, interval, optimization, and log files. If you do not specify the path for a particular reallocation scan, then the command displays all the reallocation scans.
{ [-fields <fieldname>,…​]
| [-v ]
Specify this parameter to display the output in a verbose format.
| [-instance ] }
[-vserver <vserver name>] - Vserver
Specify this parameter to display reallocation scans that match the Vserver that you specify.
[-path <text>] - Path
Specify this parameter to display reallocation scans that match the path that you specify.
[-t, -threshold <integer>] - Threshold
Specify this parameter to display reallocation scans that match the threshold that you specify.
[-id <integer>] - Job ID
Specify this parameter to display reallocation scans that match the reallocation job ID that you specify.
[-description <text>] - Job Description
Specify this parameter to display reallocation scans that match the text description that you specify.
[-state {Initial|Queued|Running|Waiting|Pausing|Paused|Quitting|Success|Failure|Reschedule|Error|Quit|Dead|Unknown|Restart|Dormant}] - Job State
Specify this parameter to display reallocation jobs that match the state that you specify.
[-progress <text>] - Execution Progress
Specify this parameter to list the running reallocation jobs whose progress indicator matches the text that you provide. For example, if you specify "Starting …​" as the text string for the progress option, then the system lists all of the jobs that are starting.
[-schedule <job_schedule>] - Schedule Name
Specify this parameter to display reallocation scans that match the schedule name that you specify. If you want a list of all job schedules, use the job schedule show command.
[-global-status <text>] - Global State of Scans
Specify this parameter to indicate if reallocation scans are on or off globally. You must type either of the following text strings:
  • "Reallocation scans are on"
  • "Reallocation scans are off"
cluster1::> volume reallocation show
Vserver     Description                 Schedule        State
vs0         /vol/vol2,space-optimized   reallocate_1d   Queued
Displays the Vserver, description, schedule, and state for the reallocation scans on the local node.
