security session limit application show
Show per-application session limits
This command shows the per-application management session limits that have been configured for each interface and application.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-interface {cli|ontapi|rest}] - Interface
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-application <text>] - Application
Selects the sessions that match this parameter value. This identifies the application for the limit. The limit with the application name -default- is the limit used for any application without a specific configured limit.
[-max-active-limit <integer>] - Max-Active Limit
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-application limits for ONTAPI management sessions.
cluster1::*> security session limit application show -interface ontapi
Interface Application          Max-Active
ontapi    -default-                     5
ontapi    custom_app                   10
2 entries were displayed.
