security session limit application show
Show per-application session limits
This command shows the per-application management session limits that have been configured for each interface and application.
[-fields <fieldname>,…]-
If you specify the
[-instance ](privilege: advanced) } -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-interface {cli|ontapi|rest}]- Interface (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the interface (CLI, ONTAPI, or REST) to which the limit applies.
[-application <text>]- Application (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the application for the limit. The limit with the application name
-default-is the limit used for any application without a specific configured limit. [-max-active-limit <integer>]- Max-Active Limit (privilege: advanced)-
Selects the sessions that match this parameter value. This identifies the configured limit that is used to throttle or reject requests.
The following example illustrates displaying the per-application limits for ONTAPI management sessions.
cluster1::*> security session limit application show -interface ontapi Interface Application Max-Active --------- -------------------- ---------- ontapi -default- 5 ontapi custom_app 10 2 entries were displayed.
