storage aggregate show
Display a list of aggregates
The storage aggregate show command displays information about aggregates. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about all aggregates:
Aggregate name
Size
Available size
Percentage used
State
Number of volumes
Node on which the aggregate is located
RAID status
To display detailed information about a single aggregate, use the -aggregate parameter.
[-fields <fieldname>,…] -
If you specify the
[-checksum ] -
If this parameter is specified, the command displays information about the checksum for all aggregates in the cluster:
Aggregate name
Checksum status (active, off, reverting, none, unknown, initializing, reinitializing, reinitialized, upgrading_phase1, upgrading_phase2)
Checksum style (none, advanced_zoned, block, mixed, WAFL, or unknown)
[-disk ] -
If this parameter is specified, the command displays disk names for all aggregates in the cluster:
Aggregate name
Number and names of disks in the aggregate
[-raid-info ] -
If this parameter is specified, the command displays information about RAID groups, RAID type, maximum RAID size, checksum state, checksum style and whether the RAID status is inconsistent.
[-instance ]} -
If this parameter is specified, the command displays detailed information about all aggregates in the cluster.
[-aggregate <aggregate name>]- Aggregate-
If this parameter is specified, the command displays detailed information about the specified aggregate.
[-storage-type {hdd | hybrid | lun | ssd | vmdisk}]- Storage Type-
If this parameter is specified, the command displays information only about the aggregates with the specified storage type. The possible values are hdd, hybrid, lun, ssd and vmdisk.
[-chksumstyle <aggrChecksumStyle>]- Checksum Style-
If this parameter is specified, the command displays information only about the aggregates that use the specified checksum style.
[-diskcount <integer>]- Number Of Disks-
If this parameter is specified, the command displays information only about the aggregates that have the specified number of disks.
[-m, -mirror <true>]- Is Mirrored-
If this parameter is specified, the command displays information only about the aggregates that have the specified mirrored value.
[-d, -disklist <disk path name>,…]- Disks for First Plex-
If this parameter is specified, the command displays information only about the aggregates that have the specified disk or disks.
[-mirror-disklist <disk path name>,…]- Disks for Mirrored Plex-
If this parameter is specified, the command displays information only about the aggregates that have the specified disk or disks present in the mirrored plex.
[-node {<nodename>|local}]- Node-
If this parameter is specified, the command displays information only about the aggregates that are located on the specified node.
[-free-space-realloc {on|off}]- Free Space Reallocation-
If this parameter is specified, the command displays whether free space reallocation is enabled on the specified aggregate.
[-ha-policy {sfo|cfo}]- HA Policy-
This optionally specifies the high-availability policy to be used in the context of a root recovery procedure. Do not modify this setting unless directed to do so by a customer support representative.
[-percent-snapshot-space <percent>]- Space Reserved for Snapshot Copies-
If this parameter is specified, the command displays information only about the aggregates that have the specified space reserved for Snapshot copies.
[-space-nearly-full-threshold-percent <percent>]- Aggregate Nearly Full Threshold Percent-
If this parameter is specified, the command displays information only about the aggregates that have the specified nearly full threshold percent.
[-space-full-threshold-percent <percent>]- Aggregate Full Threshold Percent-
If this parameter is specified, the command displays information only about the aggregates that have the specified full threshold percent.
[-hybrid-enabled {true|false}]- Hybrid Enabled-
If this parameter is specified, the command displays information only about the aggregates that are eligible to contain both SSD and non-SSD RAID groups.
[-availsize {<integer>[KB|MB|GB|TB|PB]}]- Available Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified available size.
[-chksumenabled {true|false}]- Checksum Enabled-
If this parameter is specified, the command displays information only about the aggregates that have the specified checksum setting.
[-chksumstatus <text>]- Checksum Status-
If this parameter is specified, the command displays information only about the aggregates that have the specified checksum status. The possible values for checksum status include the following: active, off, reverting, none, unknown, initializing, reinitializing, reinitialized, upgrading_phase1, and upgrading_phase2.
[-cluster <text>]- Cluster-
If this parameter is specified, the command displays information only about the aggregates that are owned by nodes in the specified cluster. By default, only local cluster aggregates are displayed.
[-cluster-id <UUID>]- Home Cluster ID-
If this parameter is specified, the command displays information only about the aggregates that are owned by nodes in the cluster specified by the cluster UUID. By default, only local cluster aggregates are displayed.
[-dr-home-id <integer>]- DR Home ID-
If this parameter is specified, the command displays information only about the aggregates whose Disaster Recovery home node has the specified system ID.
[-dr-home-name <text>]- DR Home Name-
If this parameter is specified, the command displays information only about the aggregates whose Disaster Recovery home is the specified node.
[-inofile-version <integer>]- Inofile Version (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregates whose inode files are at the specified version.
[-has-mroot {true|false}]- Has Mroot Volume-
If this parameter is specified, the command displays information about only the aggregates that contain their owning node's management root directory.
[-has-partner-mroot {true|false}]- Has Partner Node Mroot Volume-
If this parameter is specified, the command displays information about only the aggregates that contain the management root directory of their owning node's failover partner.
[-home-id <integer>]- Home ID-
If this parameter is specified, the command displays information only about the aggregates whose home node has the specified system ID.
[-home-name <text>]- Home Name-
If this parameter is specified, the command displays information only about the aggregates whose home node is the specified node.
[-hybrid-cache-size-total {<integer>[KB|MB|GB|TB|PB]}]- Total Hybrid Cache Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified total cache size in a Flash Pool.
[-hybrid {true|false}]- Hybrid-
If this parameter is specified, the command displays information only about the aggregates that currently contain both SSD and non-SSD RAID groups.
[-inconsistent {true|false}]- Inconsistent-
If this parameter is specified, the command displays information only about the aggregates that have the specified consistency.
[-is-home {true|false}]- Is Aggregate Home-
If this parameter is specified, the command displays information only about the aggregates whose home node and owner node have the same system ID.
[-s, -maxraidsize <integer>]- Max RAID Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified maximum number of disks for RAID groups.
For Flash Pools, this option controls the maximum size of the HDD RAID groups. [-cache-raid-group-size <integer>]- Flash Pool SSD Tier Maximum RAID Group Size-
If this parameter is specified, the command displays information about the maximum RAID group size for the SSD tier for Flash Pools.
This parameter is applicable only for Flash Pools. [-owner-id <integer>]- Owner ID-
If this parameter is specified, the command displays information only about the aggregates that are owned by the node with the specified system ID.
[-owner-name <text>]- Owner Name-
If this parameter is specified, the command displays information only about the aggregates that are owned by the specified node.
[-percent-used <percent>]- Used Percentage-
If this parameter is specified, the command displays information only about the aggregates that have the specified used size, as a percentage.
[-plexes <text>,…]- Plexes-
If this parameter is specified, the command displays information only about the aggregates that have the specified plex or plexes.
[-raidgroups <text>,…]- RAID Groups-
If this parameter is specified, the command displays information only about the aggregates that have the specified RAID group or groups.
[-raidstatus <text>]- RAID Status-
If this parameter is specified, the command displays information only about the aggregates that have the specified RAID status. The possible values for RAID status are normal, copying, ironing, degraded, mirror degraded, growing, initializing, invalid, needs check, partial, reconstruct, raid4, raid_ep, raid0, raid_dp, raid_tec, redirect, and wafl inconsistent. You can specify multiple values (for example, reconstruct and growing).
[-t, -raidtype {raid_tec|raid_dp|raid4|raid_ep}]- RAID Type-
If this parameter is specified, the command displays information only about the aggregates that use the specified RAID type. The possible values are
raid0for RAID 0,raid4for RAID4 of disks other thanSSD-ZNS,raid_epfor RAID4 ofSSD-ZNSdisks with additional RAID4 protection inside each disk,raid_dpfor RAID-DP,raid_tecfor RAID-TEC, andmixed_raid_typefor aggregates that include a mix of RAID types. [-resyncsnaptime <integer>]- SyncMirror Resync Snapshot Frequency in Minutes-
If this parameter is specified, the command displays information only about the aggregates whose SyncMirror Resynchronization Snapshot Frequency is the specified value.
[-root {true|false}]- Is Root-
If this parameter is specified, the command displays information about only the root aggregates in the cluster.
[-sis-metadata-space-used {<integer>[KB|MB|GB|TB|PB]}]- Space Used by Metadata for Volume Efficiency-
If this parameter is specified, the command displays information about only the aggregates with the specified space used by A-SIS metafiles for volume efficiency. This parameter is deprecated in Data ONTAP 8.2 and later. Use the volume-footprint-list-info API for details related to space usage by deduplication metadata
[-size {<integer>[KB|MB|GB|TB|PB]}]- Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified size. The size of the aggregate is reported as the size available for use by WAFL, excluding WAFL reserve and aggregate Snapshot reserve capacity. Use the storage aggregate show-space command to see the details of space utilization within an aggregate.
[-state <aggregate state>]- State-
If this parameter is specified, the command displays information only about the aggregates that have the specified state.
[-usedsize {<integer>[KB|MB|GB|TB|PB]}]- Used Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified used size.
[-uses-shared-disks {true|false}]- Uses Shared Disks-
Selects the aggregates that match this parameter value. This parameter is used to list all the aggregates that use shared HDDs or shared SSDs.
[-uuid <text>]- UUID String (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregate that has the specified UUID. This parameter is available only at the advanced privilege level and higher.
[-volcount <integer>]- Number Of Volumes-
If this parameter is specified, the command displays information only about the aggregates that have the specified number of volumes.
[-is-autobalance-eligible {true|false}]- Is Eligible for Auto Balance Aggregate (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregates that are considered by the Auto Balance Aggregate feature.
[-autobalance-state <Auto Balance Aggregate state>]- State of the aggregate being balanced (privilege: advanced)-
[-physical-used {<integer>[KB|MB|GB|TB|PB]}]- Total Physical Used Size-
If this parameter is specified, the command displays information only about the aggregates that have the specified physical used size. This differs from
total-usedspace by the space that is guaranteed for future writes. The value includes blocks in use by Snapshot copies. [-physical-used-percent <percent_no_limit>]- Physical Used Percentage-
If this parameter is specified, the command displays information only about the aggregates that have the specified physical used percent.
[-autobalance-state-change-counter <integer>]- State Change Counter for Auto Balancer (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregates that have the specified number of state change caused by the Auto Balance Aggregate feature.
[-L, -snaplock-type {non-snaplock|compliance|enterprise}]- SnapLock Type-
If this parameter is specified, the command displays information only about the aggregates that have the specified snaplock-type.
[-is-nve-capable {true|false}]- Is NVE Capable-
This parameter indicates whether or not the aggregate is capable of supporting NVE (NetApp volume encryption).
[-is-cft-precommit {true|false}]- Is in the precommit phase of Copy-Free Transition (privilege: advanced)-
Selects the aggregates that are set with this parameter value. This parameter lists all the aggregates that are in the precommit phase of a Copy-Free Transition workflow.
[-is-transition-out-of-space {true|false}]- Is a 7-Mode transitioning aggregate that is not yet committed in clustered Data ONTAP and is currently out of space (privilege: advanced)-
Selects the aggregates that match this parameter value. This parameter is used to list all the 7-mode transitioning aggregates that are not yet committed in clustered Data ONTAP, and are currently out of space.
[-autobalance-unbalanced-threshold-percent <integer>]- Threshold When Aggregate Is Considered Unbalanced (%) (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregates that have the specified unbalanced threshold percentage.
[-autobalance-available-threshold-percent <integer>]- Threshold When Aggregate Is Considered Balanced (%) (privilege: advanced)-
If this parameter is specified, the command displays information only about the aggregates that have the specified available threshold percentage.
[-resync-priority {high(fixed)|high|medium|low}]- Resynchronization Priority-
This parameter indicates the relative priority that is used to decide whether a mirrored aggregate can start a resynchronization operation or not. This field is not set for unmirrored aggregates.
Use the storage aggregate resynchronization modify command to modify this field for mirrored aggregates.
The valid values for this field are:
high(fixed): This value is reserved for Data ONTAP system aggregates, which cannot have any other value for this field. It cannot be explicitly set on a data aggregate. These aggregates always start their resynchronization operation at the first available opportunity.
high: Mirrored data aggregates with this priority value start resynchronization first.
medium: Mirrored data aggregates with this priority value start resynchronization after all the system aggregates and data aggregates with 'high' priority value have started resynchronization.
low: Mirrored data aggregates with this priority value start resynchronization only after all the other aggregates have started resynchronization.
[-data-compaction-space-saved {<integer>[KB|MB|GB|TB|PB]}]- Space Saved by Data Compaction-
This parameter indicates the amount of the space saved by Data Compaction in bytes.
[-data-compaction-space-saved-percent <percent>]- Percentage Saved by Data Compaction-
This parameter indicates the percentage of space saved in the aggregate by Data Compaction.
[-data-compacted-count {<integer>[KB|MB|GB|TB|PB]}]- Amount of compacted data-
This parameter indicates the number of bytes occupied by compacted data inside this aggregate.
[-creation-timestamp <MM/DD/YYYY HH:MM:SS>]- Timestamp of Aggregate Creation-
This parameter indicates the date and time the aggregate was created.
[-single-instance-data-logging {off|on}]- Enable SIDL-
If this parameter is specified, the command displays whether Single Instance Data Logging feature is enabled on the specified aggregate.
[-composite {true|false}]- Composite-
If this parameter is specified, the command displays information only about aggregates whose classification as a FabricPool matches the specified value. A FabricPool has an external capacity tier attached to it.
[-is-fabricpool-mirrored {true|false}]- Is FabricPool Mirrored-
If this parameter is specified, the command displays information only about FabricPools whose classification as mirrored matches the specified value. A mirrored FabricPool has a second external capacity tier attached to it.
[-composite-capacity-tier-used {<integer>[KB|MB|GB|TB|PB]}]- Capacity Tier Used Size-
If this parameter is specified, the command displays the amount of space in use in the attached external capacity tier.
[-sis-space-saved {<integer>[KB|MB|GB|TB|PB]}]- Space Saved by Storage Efficiency-
This parameter indicates the total amount of space saved by storage efficiency in bytes.
[-sis-space-saved-percent <percent>]- Percentage of Space Saved by Storage Efficiency-
This parameter indicates the percentage of space saved by storage efficiency.
[-sis-shared-count {<integer>[KB|MB|GB|TB|PB]}]- Amount of Shared bytes count by Storage Efficiency-
This parameter indicates the number of bytes shared by storage efficiency.
[-is-inactive-data-reporting-enabled {true|false}]- Inactive Data Reporting Enabled-
If this parameter is specified, the command displays whether reporting of inactive user data is enabled. This parameter is not allowed on FabricPools
[-inactive-data-reporting-start-timestamp <MM/DD/YYYY HH:MM:SS>]- Timestamp when Inactive Data Reporting was Enabled-
If this parameter is specified, the command displays the timestamp at which inactive data reporting was enabled on the aggregate. This parameter is not allowed on FabricPools.
[-encrypt-with-aggr-key {true|false}]- Enable Aggregate level Encryption-
Selects the aggregates that are encrypted with aggregate keys.
[-drive-protection-enabled {true|false}]- Aggregate uses data protected SEDs-
If this parameter is specified, the command displays whether this aggregate is entirely composed of self-encrypting drives that have data protection enabled.
[-azcs-read-optimization {on|off}]- azcs read optimization-
If this parameter is specified, the command displays whether azcs-with-compression feature is enabled.
[-space-required-for-revert {<integer>[KB|MB|GB|TB|PB]}]- Metadata Reserve Space Required For Revert (privilege: advanced)-
If this parameter is specified, the command displays the additional amount of free space needed for metadata reserve in the aggregate if the system is required to revert to an ONTAP release earlier than 9.11.1x.
The following example displays information about all aggregates that are owned by nodes in the local cluster:
cluster1::> storage aggregate show
Aggregate Size Available Used% State #Vols Nodes RAID Status
aggr0 6.21TB 1.78TB 71% online 49 cluster1-01 raid_dp,
normal
aggr1 56.04MB 55.89MB 0% online 0 cluster1-02 raid_dp,
mirrored,
normal
aggr2 1.77TB 1.63TB 8% online 1 cluster1-01 raid_dp,
normal
aggr3 1.77TB 1.73TB 2% online 2 cluster1-02 raid_dp,
normal
4 entries were displayed.
The following example displays information about an aggregate name aggr1:
cluster1::> storage aggregate show -aggregate aggr1
Aggregate: aggr1
Checksum Style: block
Number Of Disks: 6
Mirror: true
Nodes: cluster1-02
Disks for First Plex: 1.1.2,
1.1.10,
1.1.11
Disks for Mirrored Plex: 1.1.6,
1.1.8,
1.1.9
Free Space Reallocation: off
HA Policy: sfo
Space Reserved for Snapshot Copies: 5%
Hybrid Enabled: false
Available Size: 53.10MB
Block Type: 64-bit
Checksum Enabled: true
Checksum Status: active
Cluster: cluster1
Home Cluster ID: 686964a0-2172-11e3-837d-123478563412
DR Home ID: -
DR Home Name: -
Has Mroot Volume: false
Has Partner Node Mroot Volume: false
Home ID: 4050409551
Home Name: cluster1-02
Total Hybrid Cache Size: 0B
Hybrid: false
Inconsistent: false
Is Aggregate Home: true
Max RAID Size: 16
Hybrid Aggregate SSD Tier Maximum RAID Group Size: -
Owner ID: 4050409551
Owner Name: cluster1-02
Used Percentage: 0%
Plexes: /aggr1/plex0, /aggr1/plex1
RAID Groups: /aggr1/plex0/rg0 (block)
/aggr1/plex1/rg0 (block)
RAID Status: raid_dp, mirrored, normal
RAID Type: raid_dp
SyncMirror Resync Snapshot Frequency in Minutes: 60
Is Root: false
Space Used By metadata for Volume Efficiency: 0B
SnapLock Type of the Aggregate: -
State: online
Used Size: 144KB
Number Of Volumes: 0
Is Flash Pool Caching: -
Is Eligible for Auto Balance Aggregate: false
State of the aggregate being balanced: ineligible
State Change Counter for Auto Balancer: 0
Is Encrypted: true
Encryption Key ID: 40004FE3000000000303000000000000436F5DB53445FD603FB5A8A64937AA7B
Is in the precommit phase of Copy-Free Transition: false
Is a 7-Mode transitioning aggregate that is not yet committed in clustered Data ONTAP and is currently out of space: false
Threshold When Aggregate Is Considered Unbalanced (%): 70
Threshold When Aggregate Is Considered Balanced (%): 40
Resynchronization Priority: -
Space Saved by Data Compaction: 99.24MB
Percentage Saved by Data Compaction: 7%
Amount of compacted data: 99.24MB
Timestamp of Aggregate Creation: 1/3/2017 23:38:06
Enable SIDL: off
Composite: false
Capacity Tier Used Size: 0B
Space Saved by Storage Efficiency: 99.24MB
Percentage of Space Saved by Storage Efficiency: 7%
Amount of Shared bytes count by Storage Efficiency: 99.24MB
The following example displays information about aggregates that are owned by nodes in cluster1:
cluster1::> storage aggregate show -cluster cluster1
cluster1:
aggr0 6.04GB 3.13GB 48% online 2 cluster1-01 raid_dp,
mirrored,
normal
aggr1 53.24MB 12.59MB 76% online 2 cluster1-02 raid_dp,
mirrored,
normal
2 entries were displayed.
The following example displays information about aggregates that are owned by nodes in the remote cluster named cluster2:
cluster1::> storage aggregate show -cluster cluster2
cluster2:
aggr2 - - - remote_cluster
aggr3 - - - remote_cluster
The following example displays information about aggregates that are owned by nodes in all the clusters:
cluster1::> storage aggregate show -cluster *
cluster2:
cluster1:
aggr0 6.04GB 3.14GB 48% online 2 cluster1-01 raid_dp,
mirrored,
normal
mirrored,
normal
