volume rebalance file-move statistics reset
Reset statistics for file-move operations between FlexGroup constituents
The volume rebalance file-move statistics reset
command resets completed statistics for the file-move operations.
command is only supported on FlexGroup volumes.
-vserver <vserver name>
- Vserver Name-
If this parameter and the
-volume
parameter are specified, the command resets statistics for the FlexGroup constituents on the specified volume. If this parameter is specified by itself, the command resets statistics for the FlexGroup constituents on all volumes on the specified Vserver. -volume <volume name>
- Volume Name-
-vserver
parameter are specified, the command resets statistics for the FlexGroup constituents on the specified volume. If this parameter is specified by itself, the command resets statistics for the FlexGroup constituents on all volumes matching the specified name.
The following example resets completed statistics for all FlexGroup constituents on the FlexGroup volume "bld_volume" in Vserver "vs0":
cluster1::*> volume rebalance file-move statistics show -vserver vs0 -volume bld_volume Vserver: vs0 Volume: bld_volume Source Destination Constituent Files Bytes Files Bytes ------------------- ----------- ----------- ----------- ----------- bld_volume__0001 In Progress: 1 10GB 0 0B Completed: 5 100GB 0 0B bld_volume__0002 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB bld_volume__0003 In Progress: 1 10GB 0 0B Completed: 15 100GB 0 0B bld_volume__0004 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB bld_volume__0005 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB bld_volume__0006 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB bld_volume__0007 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB bld_volume__0008 In Progress: 0 0B 1 10GB Completed: 0 0B 10 150MB cluster1::*> volume rebalance file-move statistics reset -vserver vs0 -volume bld_volume ( volume rebalance file-move statistics reset) cluster1::*> volume rebalance file-move statistics show -vserver vs0 -volume bld_volume Vserver: vs0 Volume: bld_volume Source Destination Constituent Files Bytes Files Bytes ------------------- ----------- ----------- ----------- ----------- bld_volume__0001 In Progress: 1 10GB 0 0B Completed: 0 0B 0 0B bld_volume__0002 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B bld_volume__0003 In Progress: 1 10GB 0 0B Completed: 0 0B 0 0B bld_volume__0004 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B bld_volume__0005 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B bld_volume__0006 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B bld_volume__0007 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B bld_volume__0008 In Progress: 0 0B 1 10GB Completed: 0 0B 0 0B
