volume rebalance file-move statistics reset
Reset statistics for file-move operations between FlexGroup constituents
The volume rebalance file-move statistics reset command resets completed statistics for the file-move operations.
The volume rebalance file-move statistics reset command is only supported on FlexGroup volumes.
-vserver <vserver name>- Vserver Name (privilege: advanced)-
If this parameter and the
-volumeparameter are specified, the command resets statistics for the FlexGroup constituents on the specified volume. If this parameter is specified by itself, the command resets statistics for the FlexGroup constituents on all volumes on the specified Vserver. -volume <volume name>- Volume Name (privilege: advanced)-
-vserverparameter are specified, the command resets statistics for the FlexGroup constituents on the specified volume. If this parameter is specified by itself, the command resets statistics for the FlexGroup constituents on all volumes matching the specified name.
The following example resets completed statistics for all FlexGroup constituents on the FlexGroup volume "bld_volume" in Vserver "vs0":
cluster1::*> volume rebalance file-move statistics show -vserver vs0 -volume bld_volume
Vserver: vs0
Volume: bld_volume
Source Destination
Constituent Files Bytes Files Bytes
bld_volume__0001
In Progress: 1 10GB 0 0B
Completed: 5 100GB 0 0B
bld_volume__0002
In Progress: 0 0B 1 10GB
Completed: 0 0B 10 150MB
bld_volume__0003
Completed: 15 100GB 0 0B
bld_volume__0004
bld_volume__0005
bld_volume__0006
bld_volume__0007
bld_volume__0008
cluster1::*> volume rebalance file-move statistics reset -vserver vs0 -volume bld_volume
( volume rebalance file-move statistics reset)
Vserver: vs0
Volume: bld_volume
Source Destination
bld_volume__0001
Completed: 0 0B 0 0B
bld_volume__0002
bld_volume__0003
bld_volume__0004
bld_volume__0005
bld_volume__0006
bld_volume__0007
bld_volume__0008
