vserver nvme show
Show NVMe service configuration
The vserver nvme show command displays the current status of the NVMe service in a cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]- Vserver Name-
Use this parameter to display the NVMe services that match the Vserver that you specify.
[-status-admin {down|up}]- Administrative Status-
Use this parameter to display the NVMe services that match the administrative status that you specify.
[-discovery-nqn <text>]- Discovery Subsystem NQN-
Use this parameter to display the NVMe services that match the discovery subsystem NQN that you specify.
cluster1::*> vserver nvme show Vserver Status Admin ---------- ------------ vs1 up vs2 up 2 entries were displayed.
