vserver nvme show
Show NVMe service configuration
The vserver nvme show
command displays the current status of the NVMe service in a cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <Vserver Name>]
- Vserver Name-
Use this parameter to display the NVMe services that match the Vserver that you specify.
[-status-admin {down|up}]
- Administrative Status-
Use this parameter to display the NVMe services that match the administrative status that you specify.
[-discovery-nqn <text>]
- Discovery Subsystem NQN-
Use this parameter to display the NVMe services that match the discovery subsystem NQN that you specify.
[-mdns-service-discovery-enabled {true|false}]
- Use Multicast DNS Service Discovery (privilege: advanced)-
Use this parameter to display the NVMe services that match the service discovery state that you specify.
cluster1::*> vserver nvme show Vserver Status Admin ---------- ------------ vs1 up vs2 up 2 entries were displayed.
