security session limit request modify
Modify per-request session limit
This command allows modification of a per-request management session limit.
-interface {cli|ontapi|rest} - Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-request <text> - Request Name
The specified request to which this limit applies. The limit with the request name -default- is the limit used for any request without a specific configured limit.
[-max-active-limit <integer>] - Max-Active Limit
The maximum number of concurrent sessions allowed for this interface and request.
The following example illustrates modifying the limit of the number of clients simulatiously executing a specific API.
cluster1::*> security session limit request modify -interface ontapi -request storage-disk-get-iter -max-active-limit 4
