volume activity-tracking on
Enable activity tracking for a volume
The volume activity-tracking on command enables volume activity tracking on a volume.
-vserver <vserver name> - Vserver Name
This specifies the Vserver in which the volume is located.
-volume <volume name> - Volume Name
This specifies the name of the volume on which volume activity tracking is being enabled.
[-foreground <true>] - Run Operation in the Foreground
If true, the command doesn’t complete until the volume activity tracking state is on . If false, the command returns immediately, and the volume activity tracking state can be tracked using the volume activity-tracking show command.
The following examples enable volume activity tracking on a volume.
cluster::*> volume activity-tracking on -vserver vs1 -volume fv1
cluster::*> volume activity-tracking on -vserver vs1 -volume fg1
