      volume activity-tracking on
Enable activity tracking for a volume
The volume activity-tracking on command enables volume activity tracking on a volume.
- -vserver <vserver name>- Vserver Name
This specifies the Vserver in which the volume is located.
- -volume <volume name>- Volume Name
This specifies the name of the volume on which volume activity tracking is being enabled.
- [-foreground <true>]- Run Operation in the Foreground
If true, the command doesn't complete until the volume activity tracking stateison. If false, the command returns immediately, and the volume activity trackingstatecan be tracked using the volume activity-tracking show command.
The following examples enable volume activity tracking on a volume.
cluster::*> volume activity-tracking on -vserver vs1 -volume fv1
cluster::*> volume activity-tracking on -vserver vs1 -volume fg1
 PDFs
PDFs
