system node hardware nvram-encryption show
Show NVRAM device encryption information
The system node hardware nvram-encryption show
command displays the configuration of the encryption feature for the NVRAM or NVMEM data that is destaged to non-volatile flash storage.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If this parameter is specified, the command displays information about the NVRAM encryption configuration on the specified node.
[-nvram-device-name <text>]
- NVRAM Device Name-
If this parameter is specified, the command displays information about the NVRAM encryption configuration for the specified NVRAM device. Current platforms only support one device - NVRAM.0.
[-is-supported {true|false}]
- Is Encryption Support-
If this parameter is specified, the command displays information about the NVRAM encryption configuration for platforms that support it.
[-is-enabled {true|false}]
- Is Encryption Enabled-
If this parameter is specified, the command displays information about the NVRAM encryption configuration for the NVRAM or NVMEM devices where the device has the specified enabled value.
[-key-id <text>]
- Key ID of the Encryption Key-
If this parameter is specified, the command displays information about the NVRAM encryption configuration with the specified encryption Key ID used to encrypt the NVRAM or NVMEM data on flash storage.
The following example displays information about the NVRAM encryption configuration on all nodes of the cluster:
cluster1::> system node hardware nvram-encryption show Node: node1 NVRAM-Device: NVRAM.0 Supported: true Enabled: true Key-ID: 0000000000000000000000000000000000000000000000000000000000000000 Node: node2 NVRAM-Device: NVRAM.0 Supported: true Enabled: true Key-ID: 0000000000000000000000000000000000000000000000000000000000000000 2 entries are displayed.
