ONTAP commands
system node hardware nvram-encryption show
Show NVRAM device encryption information
The system node hardware nvram-encryption show command displays the configuration of the encryption feature for the NVRAM or NVMEM data that is destaged to non-volatile flash storage.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If this parameter is specified, the command displays information about the NVRAM encryption configuration on the specified node.
[-nvram-device-name <text>] - NVRAM Device Name
If this parameter is specified, the command displays information about the NVRAM encryption configuration for the specified NVRAM device. Current platforms only support one device - NVRAM.0.
[-is-supported {true|false}] - Is Encryption Support
If this parameter is specified, the command displays information about the NVRAM encryption configuration for platforms that support it.
[-is-enabled {true|false}] - Is Encryption Enabled
If this parameter is specified, the command displays information about the NVRAM encryption configuration for the NVRAM or NVMEM devices where the device has the specified enabled value.
[-key-id <text>] - Key ID of the Encryption Key
If this parameter is specified, the command displays information about the NVRAM encryption configuration with the specified encryption Key ID used to encrypt the NVRAM or NVMEM data on flash storage.
The following example displays information about the NVRAM encryption configuration on all nodes of the cluster:
cluster1::> system node hardware nvram-encryption show
         Node: node1
 NVRAM-Device: NVRAM.0
    Supported: true
      Enabled: true
       Key-ID: 0000000000000000000000000000000000000000000000000000000000000000
         Node: node2
    Supported: true
      Enabled: true
 2 entries are displayed.
