snaplock event-retention policy delete
- PDF of this doc site
Creating your file...
Your file is ready
Delete SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy delete
command is used to delete Event Based Retention (EBR) policies for a Vserver. Only a user with security login role vsadmin-snaplock
is allowed to perform this operation.
-vserver <vserver name>
- Vserver Name-
If this parameter is specified, the command deletes all EBR policies that match the specified Vserver.
-name <text>
- Policy Name-
name
The following example deletes retention policy "p1" for Vserver "vs1":
vs1::> snaplock event-retention policy delete -name p1
