ONTAP commands
snaplock event-retention policy delete
Delete SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy delete command is used to delete Event Based Retention (EBR) policies for a Vserver. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
If this parameter is specified, the command deletes all EBR policies that match the specified Vserver.
-name <text> - Policy Name
If this parameter is specified, the command deletes all EBR policies that match the specified name .
The following example deletes retention policy "p1" for Vserver "vs1":
vs1::> snaplock event-retention policy delete -name p1
