statistics vserver show
Vserver throughput and latency metrics
This command continuously displays performance data for Vservers at a regular interval. The command output displays data in the following columns:
Vserver - Vserver name.
Total Ops - total number of operations per second.
Read Ops - read operations per second.
Write Ops - write operations per second.
Other Ops - other operations per second.
Read (Bps) - read throughput in bytes per second.
Write (Bps) - write throughput in bytes per second.
Latency(us) - average latency for an operation in microseconds.
- [-vserver <vserver name>]- Vserver
Selects the vserver for which you want to display performance data.
- [-sort-key <text>]- Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
- -interval <integer>- Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
- -iterations <integer>- Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
- -max <integer>- Maximum Number of Instances
Specifies the maximum number of Vservers to display. The default setting is 25.
The following example displays Vserver statistics:
cluster1::> statistics vserver show
cluster1 : 12/31/2013 16:00:04
         *Total Read Write Other   Read Write Latency
 Vserver    Ops  Ops   Ops   Ops  (Bps) (Bps)    (us)
     vs1     58   13    15    29 310585  3014      39
     vs2     56    0    11    45   8192 28826      47
 PDFs
PDFs
