ONTAP commands
statistics vserver show
Vserver throughput and latency metrics
This command continuously displays performance data for Vservers at a regular interval. The command output displays data in the following columns:
  • Vserver - Vserver name.
  • Total Ops - total number of operations per second.
  • Read Ops - read operations per second.
  • Write Ops - write operations per second.
  • Other Ops - other operations per second.
  • Read (Bps) - read throughput in bytes per second.
  • Write (Bps) - write throughput in bytes per second.
  • Latency(us) - average latency for an operation in microseconds.
[-vserver <vserver name>] - Vserver
Selects the vserver for which you want to display performance data.
[-sort-key <text>] - Column to Sort By
If this parameter is specified, the command displays statistics sorted by the specified column.
-interval <integer> - Interval
Specifies, in seconds, the interval between statistics updates. The default setting is 5 seconds.
-iterations <integer> - Iterations
Specifies the number of iterations the command runs before terminating. The default setting is 1. If the number is 0 (zero), the command continues to run until you interrupt it by pressing Ctrl-C.
-max <integer> - Maximum Number of Instances
Specifies the maximum number of Vservers to display. The default setting is 25.
The following example displays Vserver statistics:
cluster1::> statistics vserver show
cluster1 : 12/31/2013 16:00:04
         *Total Read Write Other   Read Write Latency
 Vserver    Ops  Ops   Ops   Ops  (Bps) (Bps)    (us)
     vs1     58   13    15    29 310585  3014      39
     vs2     56    0    11    45   8192 28826      47
