system node revert-to
Revert a node to a previous release of Data ONTAP
The system node revert-to command reverts a node's cluster configuration to the given version. After the system node revert-to command has finished, the revert_to command must be run from the nodeshell. The revert_to command reverts the filesystem on individual nodes to the target release. Before running revert-to in the cluster shell, the target release must be installed on the node.
-node {<nodename>|local}- Node (privilege: advanced)-
Specifies the node that is to be reverted. The value
localspecifies the current node. -version <revert version>- Data ONTAP Version (privilege: advanced)-
Specifies the version of Data ONTAP to which the node is to be reverted.
[-check-only <true>]- Capability Check (privilege: advanced)-
If set to
true, this parameter specifies that the cluster configuration revert should perform checks to verify all of the preconditions necessary for revert-to to complete successfully. Setting the parameter totruedoes not run through the actual revert process. By default this option is set tofalse.
The command in the following example reverts cluster configuration of a node named node1 to Data ONTAP version 9.10
cluster1::*> system node revert-to -node node1 -version 9.10
