Command reference
system node revert-to
Revert a node to a previous release of Data ONTAP
The system node revert-to command reverts a node's cluster configuration to the given version. After the system node revert-to command has finished, the revert_to command must be run from the nodeshell. The revert_to command reverts the filesystem on individual nodes to the target release. Before running revert-to in the cluster shell, the target release must be installed on the node.
-node {<nodename>|local} - Node (privilege: advanced)
Specifies the node that is to be reverted. The value local specifies the current node.
-version <revert version> - Data ONTAP Version (privilege: advanced)
Specifies the version of ONTAP to which the node is to be reverted.
[-check-only <true>] - Capability Check (privilege: advanced)
If set to true , this parameter specifies that the cluster configuration revert should perform checks to verify all of the preconditions necessary for revert-to to complete successfully. Setting the parameter to true does not run through the actual revert process. By default this option is set to false .
The command in the following example reverts cluster configuration of a node named node1 to ONTAP version 9.17
cluster1::*> system node revert-to -node node1 -version 9.17
