ONTAP commands
metrocluster check config-replication show-capture-status
Display MetroCluster capture status information
The metrocluster check config-replication show-capture-status command indicates whether or not a configuration change that would prevent a negotiated switchover is currently being captured for replication.
The following example shows the execution of the command in a MetroCluster configuration when capture is not in progress:
cluster1::*> metrocluster check config-replication show-capture-status
Is Capture in Progress: false
