      statistics samples delete
Delete statistics samples
This command deletes samples that you created using the statistics start command.
- -vserver <vserver name>- Vserver (privilege: advanced)
Selects the Vserver for which you want to delete the sample. The default Vserver is admin Vserver.
- -sample-id <text>- Sample Identifier (privilege: advanced)
Specifies the sample that you want to delete. This is a required parameter.
The following example deletes the sample "smpl_1":
cluster1::*> statistics samples delete -sample-id smpl_1
 PDFs
PDFs
