storage aggregate show-spare-disks
Display spare disks
The command storage aggregate show-spare-disks
displays information about spare disks. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays information about all spare disks in the cluster.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-partition-info ]
Displays the following information about root-data and root-data1-data2 partitioned spares.
Disk
Type
Class
RPM
Checksum
Local Data Usable
Local Data1 Usable
Local Data2 Usable
Local Root Usable
Physical Size
Status
[-instance ]
If this parameter is specified, the command displays detailed information about each spare disk.
[-original-owner <text>]
- Original Owner-
Selects the spare disks that match this parameter value.
[-disk <disk path name>]
- Disk Name-
[-checksum-style {advanced_zoned | block | none}]
- Checksum Style-
Selects the spare disks that match this parameter value. Possible values are:
block — Supports block checksum
advanced_zoned — Supports advanced zone checksum
none — No checksum support
[-disk-type {ATA | BSAS | FCAL | FSAS | LUN | MSATA | SAS | SSD | VMDISK | SSD-NVM | SSD-CAP | SSD-ZNS | VMLUN | VMLUN-SSD}]
- Disk Type-
[-effective-disk-type {ATA | BSAS | FCAL | FSAS | LUN | MSATA | SAS | SSD | VMDISK | SSD-NVM | SSD-CAP | SSD-ZNS | VMLUN | VMLUN-SSD}]
- Effective Disk Type-
Hard disk drives with the same
effective-disk-type
value may be mixed together in the same aggregate depending upon the system’sraid.mix.hdd.disktype.capacity
andraid.mix.hdd.disktype.performance
option settings. Solid state drives with the sameeffective-disk-type
value may be mixed together in the same aggregate depending upon the system’sraid.mix.disktype.solid_state
option setting. [-standard-disk-type {SATA | FC | NL-SAS | LUN | SAS | SCSI | SSD | VM-DISK | NVMe-SSD | SSD-CAP | SSD-ZNS | VM-LUN | VM-LUN-SSDS}]
- Standard Disk Type-
[-disk-class {capacity | performance | archive | solid-state | array | virtual}]
- Disk Class-
capacity — Capacity-oriented, near-line disk types. Includes disk types FSAS, BSAS and ATA.
performance — Performance-oriented, enterprise class disk types. Includes disk types FCAL and SAS.
archive — Archive class SATA disks in multi-disk carrier storage shelves. Includes disk type MSATA.
solid-state — Solid-state drives. Includes disk type SSD, SSD-CAP and SSD-NVM.
array — Logical storage devices backed by storage arrays and used by Data ONTAP as disks. Includes disk type LUN.
virtual — Virtual disks that are formatted and managed by the hypervisor. Includes disk type VMDISK.
Disks with the same
disk-class
value are compatible for use in the same aggregate. -
[-disk-rpm <integer>]
- Disk RPM-
[-effective-disk-rpm <integer>]
- Effective Disk RPM-
effective-disk-rpm
value may be mixed together in the same aggregate depending upon the system’sraid.mix.hdd.rpm.capacity
andraid.mix.hdd.rpm.performance
option settings. [-syncmirror-pool <text>]
- Pool Number-
[-owner-name {<nodename>|local}]
- Current Owner-
[-home-owner-name {<nodename>|local}]
- Home Owner-
[-dr-owner-name {<nodename>|local}]
- DR Home Owner-
[-usable-size-blks <integer>]
- Disk Usable Size in 4K blocks-
[-local-usable-data-size-blks <integer>]
- Local Node Data Usable Size in 4K blocks-
Disks that have two partitions can be used for one root aggregate and one data aggregate.
Disks that have three partitions can be used for one root aggregate and one or two data aggregates.
This value describes the data partition size (of root-data partitioned disk) or the combined data1 + data2 partition size (of root-data1-data2 partitioned disk) in 4KB blocks.
[-local-usable-root-size-blks <integer>]
- Local Node Root Usable Size in 4K blocks-
This value describes the root partition size in 4KB blocks.
[-usable-size {<integer>[KB|MB|GB|TB|PB]}]
- Disk Usable Size-
[-total-size {<integer>[KB|MB|GB|TB|PB]}]
- Total Size-
[-local-usable-data-size {<integer>[KB|MB|GB|TB|PB]}]
- Local Node Data Usable Size-
This value describes the data partition size (of root-data partitioned disk) or the combined data1 + data2 partition size (of root-data1-data2 partitioned disk) in auto-scaled units.
[-local-usable-root-size {<integer>[KB|MB|GB|TB|PB]}]
- Local Node Root Usable Size-
This value describes the root partition size in auto-scaled units.
[-is-disk-zeroed {true|false}]
- Is Disk Zeroed?-
When disks are zeroed, they can be provisioned directly into aggregates which avoids a lengthy zeroing process.
[-is-disk-zeroing {true|false}]
- Is Disk Zeroing?-
[-zeroing-percent <percent>]
- Zeroing Percentage Completed-
[-is-sparecore {true|false}]
- Sparecore Disk?-
[-sparecore-status <Spare core status>]
- Sparecore Status-
[-sparecore-percent <percent>]
- Sparecore Percentage Completed-
[-is-disk-shared {true|false}]
- Is Disk Shared?-
Shared disks have partitions that allow them to be used in multiple aggregates and between nodes in an HA pair. When set to
true
, this parameter selects shared disks in which the root partition and/or the data partition is a spare. When set tofalse
only spare disks without partitions are displayed. When this parameter is not used, all spare disks are displayed. [-is-disk-offline {true|false}]
- Is Disk Offline?-
Disk offline events are typically temporary events which allow Data ONTAP to perform background error recovery activity.
[-is-disk-sick {true|false}]
- Is Disk Sick?-
A sick disk triggers Rapid RAID Recovery to copy data to a spare drive. At the end of the process the sick disk is marked as
broken
. [-is-disk-left-behind {true|false}]
- Is Disk Left Behind Spare?-
Disks are left behind if they are not responding during a giveback or switchback event.
[-local-usable-data1-size-blks <integer>]
- Local Node Data1 Usable Size in 4K blocks-
This value describes the data1 partition size of a root-data1-data2 partitioned disk in 4KB blocks.
[-local-usable-data2-size-blks <integer>]
- Local Node Data2 Usable Size in 4K blocks-
This value describes the data2 partition size of a root-data1-data2 partitioned disk in 4KB blocks.
[-local-usable-data1-size {<integer>[KB|MB|GB|TB|PB]}]
- Local Node Data1 Usable Size-
This value describes the data1 partition size of a root-data1-data2 partitioned disk in auto-scaled units.
[-local-usable-data2-size {<integer>[KB|MB|GB|TB|PB]}]
- Local Node Data2 Usable Size-
This value describes the data2 partition size of a root-data1-data2 partitioned disk in auto-scaled units.
Display spare disks owned by node node-b
cluster1::> storage aggregate show-spare-disks -owner-name node-b Original Owner: node-b Pool0 Spare Pool Usable Physical Disk Type Class RPM Checksum Size Size Status ---------------- ----- ----------- ------ -------------- -------- -------- -------- 1.1.13 BSAS capacity 7200 block 827.7GB 828.0GB zeroed 1.1.15 BSAS capacity 7200 block 413.2GB 414.0GB zeroed Original Owner: node-b Pool0 Partitioned Spares Local Local Data Root Physical Disk Type Class RPM Checksum Usable Usable Size Status ---------------- ----- ----------- ------ -------------- -------- -------- -------- -------- 1.0.8 SAS performance 10000 block 472.9GB 73.89GB 547.1GB zeroed
Check on the progress of a previous disk zeroing command.
cluster1::> storage aggregate show-spare-disks -owner-name node-b -zeroing-percent >0 Original Owner: node-b Pool0 Spare Pool Usable Physical Disk Type Class RPM Checksum Size Size Status ---------------- ----- ----------- ------ -------------- -------- -------- -------- 1.1.13 BSAS capacity 7200 block 827.7GB 828.0GB zeroing, 17% done 1.1.15 BSAS capacity 7200 block 413.2GB 414.0GB zeroing, 28% done 2 entries were displayed.
