vserver cifs domain preferred-dc show
Display a list of preferred domain controllers
The vserver cifs domain preferred-dc show command displays lists of preferred domain controllers by Vserver and domain.
- { [-fields <fieldname>,…]
If you specify the -fields <fieldname>, …parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify.
- | [-instance ]}
If you specify the -instanceparameter, the command displays detailed information about all fields.
- [-vserver <vserver name>]- Vserver
This parameter specifies the name of the Vserver for which you want to display preferred domain controllers.
- [-domain <TextNoCase>]- Fully Qualified Domain Name
This parameter specifies the fully-qualified name of the domain of the domain controllers to display.
- [-preferred-dc <InetAddress>,…]- Preferred Domain Controllers
This parameter specifies a comma-delimited list of IP addresses for domain controllers to display.
The following example displays all preferred domain controllers for all Vservers:
cluster1::> vserver cifs domain preferred-dc show Vserver Domain Name Preferred Domain Controllers -------------- ----------------------------- ---------------------------------- vs1 example.com 192.168.0.100, 192.168.0.101
 PDFs
PDFs
