security key-manager onboard enable
Enable the Onboard Key Manager
This command enables the Onboard Key Manager for the admin Vserver.
[-cc-mode-enabled {yes|no}]- Enable Common Criteria Mode?-
Use this parameter to specify whether the Common Critieria (CC) mode should be enabled or not. When CC mode is enabled, you are required to provide a cluster passphrase that is between 64 and 256 ASCII character long, and you are required to enter that passphrase each time a node reboots. CC mode cannot be enabled in a MetroCluster configuration.
The following example enables the Onboard Key Manager for the admin Vserver cluster-1:
cluster-1::> security key-manager onboard enable Enter the cluster-wide passphrase for the Onboard Key Manager: Re-enter the cluster-wide passphrase: After configuring the Onboard Key Manager, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. To view the data, use the "security key-manager onboard show-backup" command.
