vserver export-policy config-checker stop
Stop export policy configuration checker job
The vserver export-policy config-checker stop command stops running export policy configuration checker job.
Note Export policy configuration checker stop command only works if the keys provided are same as the keys provided at the time of starting export policy configuration checker job.
-vserver <vserver name> - Vserver
If you specify this parameter, the command stops export policy configuration checker job, if any export policy configuration checker job is running for the specified Vserver.
[-policy <export policy name>] - Export Policy Name
If you specify this parameter, the command stops export policy configuration checker job, if any export policy configuration checker job is running for the specified policy.
The following example stop an export policy configuration checker job for Vserver vs2 and policy default:
cluster1::> vserver export-policy config-checker stop -vserver vs2 -policy default
