network port broadcast-domain modify
Modify a layer 2 broadcast domain
Modify a broadcast domain.
-ipspace <IPspace> - IPspace Name
The IPspace to which the broadcast domain belongs.
-broadcast-domain <Broadcast Domain> - Layer 2 Broadcast Domain
The name of the broadcast domain.
[-mtu <integer>] - Configured MTU
MTU of the broadcast domain. All ports that belong to the broadcast domain are modified.
The following example modifies the mtu attribute of broadcast domain "mgmt" in IPspace "Default" to 1500
cluster1::network port broadcast-domain*> modify -ipspace Default -broadcast-domain mgmt -mtu 1500
