system health subsystem show
Display the health of subsystems
The system health subsystem show
command displays the health status of each subsystem for which health monitoring is available. This command aggregates subsystem health status from each node in the cluster. A subsystem’s health status changes to "degraded" when a health monitor raises an alert. You can use the system health alert show command to display information about generated alerts.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-subsystem <hm_subsystem>]
- Subsystem-
Selects the specified subsystem.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Health-
Selects subsystems that have the specified health status.
[-init-state {Invalid|Initailizing|Initialized|Starting_Discovery|Starting_Re-Discovery|Discovery_Done_Partially|Discovery_Done}]
- Initialization State-
Selects subsystems that have the specified initialization state.
[-outstanding-alert-count <integer>]
- Number of Outstanding Alerts-
Selects subsystems that have the specified number of outstanding alerts.
[-suppressed-alert-count <integer>]
- Number of Suppressed Alerts-
Selects subsystems that have the specified number of suppressed alerts.
[-node {<nodename>|local}]
- Node-
Selects subsystems for the specified node.
[-refresh-interval <[<integer>h][<integer>m][<integer>s]>,…]
- Subsystem Refresh Interval-
The refresh interval is in minutes. A value of zero disables the sub-system refresh until a reboot or restart of the subsystem process.
The example below displays the health status of each subsystem:
cluster1::> system health subsystem show Subsystem Health ----------------- ------------------ SAS-connect degraded Switch-Health OK CIFS-NDO OK
The example below displays detailed information about the health status of each subsystem:
cluster1::> system health subsystem show -instance Subsystem: SAS-connect Health: degraded Initialization State: initialized Number of Outstanding Alerts: 0 Number of Suppressed Alerts: 0 Node: node1,node2 Subsystem Refresh Interval: 30m, 30m Subsystem: Switch-Health Health: ok Initialization State: initialized Number of Outstanding Alerts: 0 Number of Suppressed Alerts: 0 Node: node1 Subsystem Refresh Interval: 5m Subsystem: CIFS-NDO Health: OK Initialization State: initialized Number of Outstanding Alerts: 0 Number of Suppressed Alerts: 0 Node: node1 Subsystem Refresh Interval: 5m
