system health alert show
View system health alerts
The system health alert show
command displays information about all the alerts generated on the system. Using -instance will add detailed information.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays the following additional information about each alert:
Node name
Resource name
Severity of the alert
Time of alert generation
Suppress state of the alert
Acknowledge state of the alert
Probable cause for the alert
Possible effect due to the alert
Recommended corrective actions to follow
[-node {<nodename>|local}]
- Node-
Selects the alerts generated for the specified node.
[-monitor <hm_type>]
- Monitor-
Selects the alerts with the specified monitor name.
[-alert-id <text>]
- Alert ID-
Selects the alerts with the specified alert ID.
[-alerting-resource <text>]
- Alerting Resource-
Selects the alerts with the specified alerting resource name.
[-subsystem <hm_subsystem>]
- Subsystem-
Selects the alerts generated on the monitoring subsystem.
[-indication-time <Date>]
- Indication Time-
Selects the alerts with the specified indicated time.
[-perceived-severity <hm_perceived_sev>]
- Perceived Severity-
Selects the alerts with the perceived severity level.
[-probable-cause <hm_probable_cause>]
- Probable Cause-
Selects the alerts that contain the specified probable cause.
[-probable-cause-description <text>]
- Description-
Selects the alerts containing the specified probable cause description.
[-corrective-actions <text>]
- Corrective Actions-
Selects the alerts with the specified recommended corrective action.
[-possible-effect <text>]
- Possible Effect-
Selects the alerts with the specified possible effect.
[-acknowledge {true|false}]
- Acknowledge-
Selects the alerts with the specified acknowledgement status.
[-suppress {true|false}]
- Suppress-
Selects the alerts with the specified suppressor field status of true or false.
[-policy <text>]
- Policy-
Selects the alerts with the specified policy name.
[-acknowledger <text>]
- Acknowledger-
Selects the alerts with the specified acknowledger field.
[-suppressor <text>]
- Suppressor-
Selects the alerts with the specified suppressor field.
[-additional-info <text>,…]
- Additional Information-
Selects the alerts with the specified additional information.
[-alerting-resource-name <text>]
- Alerting Resource Name-
[-tags <hm_alert_type>,…]
- Additional Alert Tags-
Selects the alerts with the specified keywords.
The example below displays information about all the alerts generated in the cluster:
cluster1::> system health alert show Node: node1 Alert ID: DualPathToDiskShelf_Alert Resource: Shelf ID 2 Severity: Major Suppress: false Acknowledge: false Tags: quality-of-service, nondisruptive-upgrade Probable Cause: Disk shelf 2 does not have two paths to controller node1. Possible Effect: Access to disk shelf 2 via controller node1 will be lost with a single hardware component failure (e.g. cable, HBA, or IOM failure). Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2. 2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide. 3. Reboot the halted controllers. 4. Contact support personnel if the alert persists.
The example below displays additional information about a specific alert generated in the cluster:
cluster1::> system health alert show -monitor node-connect -alert-id DualPathToDiskShelf_Alert -instance Node: node1 Monitor: node-connect Alert ID: DualPathToDiskShelf_Alert Alerting Resource: 50:05:0c:c1:02:00:0f:02 Subsystem: SAS-connect Indication Time: Mon Mar 21 10:26:38 2011 Perceived Severity: Major Probable Cause: Connection_establishment_error Description: Disk shelf 2 does not have two paths to controller node1. Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2. 2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide. 3. Reboot the halted controllers. 4. Contact support personnel if the alert persists. Possible Effect: Access to disk shelf 2 via controller node1 will be lost with a single hardware component failure (e.g. cable, HBA, or IOM failure). Acknowledge: false Suppress: false Policy: DualPathToDiskShelf_Policy Acknowledger: - Suppressor: - Additional Information: Shelf uuid: 50:05:0c:c1:02:00:0f:02 Shelf id: 2 Shelf Name: 4d.shelf2 Number of Paths: 1 Number of Disks: 6 Adapter connected to IOMA: Adapter connected to IOMB: 4d Alerting Resource Name: Shelf ID 2 Additional Alert Tags: quality-of-service, nondisruptive-upgrade
