storage shelf location-led show
Display the Location LED status
The storage shelf location-led show
command displays the state of shelf location LED.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-shelf-name <text>]
- Shelf Name-
Selects the shelves whose shelf-name matches this parameter value.
[-node {<nodename>|local}]
- Node Name-
Selects the nodes that match this parameter value.
[-stack-id <integer>]
- Stack ID-
Selects the shelves whose stack-id matches this parameter value.
[-shelf-id <integer>]
- Shelf ID-
Selects the shelves whose shelf-id matches this parameter value.
[-led-status {on|off}]
- Location LED-
Shows the state of the shelf location LED.
The following example shows the state of the shelf location LED for each shelf.
cluster1::> storage shelf location-led show Shelf Name Stack ID Shelf ID LED Status ---------- -------- -------- ----------- 8.2 8 2 off 8.3 8 3 off 6.0 6 0 unsupported 8.1 8 1 off 4 entries were displayed.
