ONTAP commands
storage shelf location-led show
Display the Location LED status
The storage shelf location-led show command displays the state of shelf location LED.
{ [-fields <fieldname>,…​]
| [-instance ]
[-shelf-name <text>] - Shelf Name
Selects the shelves whose shelf-name matches this parameter value.
[-node {<nodename>|local}] - Node Name
Selects the nodes that match this parameter value.
[-stack-id <integer>] - Stack ID
Selects the shelves whose stack-id matches this parameter value.
[-shelf-id <integer>] - Shelf ID
Selects the shelves whose shelf-id matches this parameter value.
[-led-status {on|off}] - Location LED
Shows the state of the shelf location LED.
The following example shows the state of the shelf location LED for each shelf.
cluster1::> storage shelf location-led show
Shelf Name Stack ID Shelf ID LED Status
       8.2        8        2 off
       8.3        8        3 off
       6.0        6        0 unsupported
       8.1        8        1 off
4 entries were displayed.
