lun copy modify
Modify an ongoing LUN copy operation
The lun copy modify
command modifies the maximum throughput of an ongoing copy operation.
-vserver <Vserver Name>
- Vserver Name -
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path>
- Destination Path-
Specifies the full path to the new LUN, in the format /vol/<volume>[/<qtree>]/<lun>.
-max-throughput {<integer>[KB|MB|GB|TB|PB]}
- Maximum Transfer Rate (per sec)-
Specifies the maximum amount of data, in bytes, that can be transferred per second in support of this operation. This mechanism can be used to throttle a transfer, to reduce its impact on the performance of the source and destination nodes.
The specified value will be rounded up to the nearest megabyte.
cluster1::> lun copy modify -vserver vs1 -destination-path /vol/vol2/lun2 -max-throughput 25MB
Modifies the maximum throughput for the ongoing copy job identified by Vserver vs1
and destination path /vol/vol2/lun2
to 25 MB/sec.
