ONTAP commands
lun copy modify
Modify an ongoing LUN copy operation
The lun copy modify command modifies the maximum throughput of an ongoing copy operation.
{ -vserver <Vserver Name> - Vserver Name
Specifies the name of the Vserver that will host the destination LUN.
-destination-path <path> - Destination Path
Specifies the path of the new LUN. Examples of correct LUN paths: /vol/vol1/lun1 and /vol/vol1/qtree1/lun1
-max-throughput {<integer>[KB|MB|GB|TB|PB]} - Maximum Transfer Rate (per sec)
Specifies the maximum amount of data, in bytes, that can be transferred per second in support of this operation. This mechanism can be used to throttle a transfer, to reduce its impact on the performance of the source and destination nodes.
Note The specified value will be rounded up to the nearest megabyte.
cluster1::> lun copy modify -vserver vs1 -destination-path /vol/vol2/lun2 -max-throughput 25MB
Modifies the maximum throughput for the ongoing copy job identified by Vserver vs1 and destination path /vol/vol2/lun2 to 25 MB/sec.
