metrocluster transition enable
Enable Transition
The metrocluster transition enable
command is used to start the transition from a MetroCluster FC to a MetroCluster IP configuration. The command sets the transition mode on the local and partner cluster.
-transition-mode <Mode For FC To Ip Transition>
- Transition Mode (privilege: advanced)-
This parameter specifies the setting for the transition-mode.
[-force {true|false}]
- Force enable (privilege: advanced)-
This optional parameter forces the setting for the transition-mode.
The following example shows how to enable the non-disruptive transition mode:
clusA::> metrocluster transition enable transition-mode non-disruptive clusA::> metrocluster transition show-mode Transition Mode -------------------------- non-disruptive
The following example shows how to enable the disruptive transition mode:
clusA::> metrocluster transition enable transition-mode disruptive clusA::> metrocluster transition show-mode Transition Mode -------------------------- disruptive
