Command reference
metrocluster transition enable
Enable Transition
The metrocluster transition enable command is used to start the transition from a MetroCluster FC to a MetroCluster IP configuration. The command sets the transition mode on the local and partner cluster.
-transition-mode <Mode For FC To Ip Transition> - Transition Mode (privilege: advanced)
This parameter specifies the setting for the transition-mode.
[-force {true|false}] - Force enable (privilege: advanced)
This optional parameter forces the setting for the transition-mode.
The following example shows how to enable the non-disruptive transition mode:
clusA::> metrocluster transition enable transition-mode non-disruptive
clusA::> metrocluster transition show-mode
 Transition Mode
 non-disruptive
The following example shows how to enable the disruptive transition mode:
clusA::> metrocluster transition enable transition-mode disruptive
 Transition Mode
disruptive
