system node virtual-machine instance show-system-disks
Display information about virtual machine system disks
The system node virtual-machine instance show-system-disks
command displays information about the system disks (non-data disks) attached to the virtual machine. Data disk information is available using the command storage disk show-virtual-machine-disk-info
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node Name-
Selects disk information for nodes that match this parameter.
[-vmdisk-purpose <text>]
- Purpose of the System Disk-
Selects disk information for disks that match this parameter. Values include:
Boot
,NVRAM
, andCore
. [-vmdisk-type <text>]
- Type of the System Disk-
Selects disk information for disks that match this parameter. Possible values are:
VMDISK
,SSD
. [-vmdisk-name <text>]
- System Disk Name-
Selects disk information for disks that match this parameter. The virtual machine ID of the system disk.
[-vmdisk-capacity <text>]
- Size of the System Disk (GB)-
Selects disk information for disks that match this parameter. The size of the system disk.
[-vmdisk-file-name <text>]
- File Name of the System Disk Used By the Hypervisor-
Selects disk information for disks that match this parameter. The virtual machine file name of the disk. Each system disk is mapped to a unique VM disk file.
The following example shows typical output from the command.
cluster1::> system node virtual-machine instance show-system-disks Disk Disk Disk Disk Node Purpose Type Name Capacity GB VM Disk File Name ---- ------- ------- ---- ----------- --------------------------------------- node1 boot SSD da0 10 node1-vm-disk-boot nvram SSD da1 500 node1-vm-disk-nvram core VMDISK da2 216 node1-vm-disk-core
