storage shelf drawer show-phy
Display a list of PHYs per drawer
The storage shelf drawer show-phy
command displays information for drawer PHYs in the storage system. If no parameters are specified, the default command displays the following information about PHYs:
Shelf Name
Drawer Number
PHY Number
Type
SAS Address
State
To display detailed information about a single PHY, use the -shelf
, -drawer
, and -phy
parameters.
[-fields <fieldname>,…]
Displays the specified fields for all drawer PHYs, in column style output.
[-instance ]
Displays expanded information for all drawer PHYs in the system. If a shelf, drawer, and PHY are specified, then this parameter displays the same detailed information for the PHY you specify as does the -shelf, -drawer, and -phy parameters.
[-shelf <text>]
- Shelf Name-
Displays the PHYs in the storage shelf that matches the specified shelf name.
[-drawer <integer>]
- Drawer Number-
Displays the PHYs in the drawers that match the specified drawer number.
[-phy <integer>]
- PHY Number-
Displays the PHYs that match the specified PHY number.
[-node {<nodename>|local}]
- Node Name-
Displays the PHYs that are present for the specified node.
[-type {unknown|disk|virtual|input}]
- Type-
Displays the PHYs with the specified type.
[-physical-id <integer>]
- Physical ID-
Displays the PHYs that match the specified physical-id.
[-sas-address <text>]
- Attached SAS Address-
Displays the PHYs with the specified attached sas address.
[-state-a {unknown|enabled|disabled}]
- State Module A-
Displays the PHYs for which module A has the specified state.
[-state-b {unknown|enabled|disabled}]
- State Module B-
Displays the PHYs for which module B has the specified state.
[-status-a <Drawer PHY Status>]
- Status Module A-
Displays the PHYs with module A currently operating under the specified status.
[-status-b <Drawer PHY Status>]
- Status Module B-
Displays the PHYs with module B currently operating under the specified status.
The following example displays information about all drawer PHYs:
cluster1::> storage shelf drawer show-phy Shelf Drawer PHY # Type SAS Address PHY State A/B ----- ------ ----- -------- ----------------- ----------------- 2.5 1 0 disk 00c5005079183f85 enabled/enabled 1 disk - enabled/enabled 2 disk - enabled/enabled 3 disk 00c50050e1183f85 enabled/enabled 4 disk - enabled/enabled 5 disk - enabled/enabled 6 disk 00c50050dd183f85 enabled/enabled 7 disk - enabled/enabled 8 disk - enabled/enabled 9 disk 00c500502d163f85 enabled/enabled 10 disk - enabled/enabled 11 disk - enabled/enabled 12 input 80090a5045e46f06 enabled/enabled 13 input 80090a5045e46f06 enabled/enabled 14 input 80090a5045e46f06 enabled/enabled 15 input 80090a5045e46f06 enabled/enabled 16 virtual 8a090a503dd01b17 enabled/enabled 2 0 disk 00c500503d0e3d85 enabled/enabled 1 disk - enabled/enabled 2 disk - enabled/enabled 3 disk 00c50050e9173f85 enabled/enabled 4 disk - enabled/enabled 5 disk - enabled/enabled 6 disk 00c50050a9163f85 enabled/enabled 7 disk - enabled/enabled 8 disk - enabled/enabled 9 disk 00c5005021173f85 enabled/enabled 10 disk - enabled/enabled 11 disk - enabled/enabled 12 input 80090a5045e46f06 enabled/enabled 13 input 80090a5045e46f06 enabled/enabled 14 input 80090a5045e46f06 enabled/enabled 15 input 80090a5045e46f06 enabled/enabled 16 virtual 8a090a503d90fd16 enabled/enabled 3 0 disk 00c500503d163f85 enabled/enabled 1 disk - enabled/enabled 2 disk - enabled/enabled 3 disk 00c50050bd163f85 enabled/enabled 4 disk - enabled/enabled 5 disk - enabled/enabled 6 disk 00c50050c1d44085 enabled/enabled 7 disk - enabled/enabled 8 disk - enabled/enabled 9 disk 00c50050f1d54085 enabled/enabled 10 disk - enabled/enabled 11 disk - enabled/enabled 12 input 80090a5045e46f06 enabled/enabled 13 input 80090a5045e46f06 enabled/enabled 14 input 80090a5045e46f06 enabled/enabled 15 input 80090a5045e46f06 enabled/enabled 16 virtual 8a090a503d202a17 enabled/enabled 4 0 disk 00c50050fdd54085 enabled/enabled 1 disk - enabled/enabled 2 disk - enabled/enabled 3 disk 00c50050d9d44085 enabled/enabled 4 disk a0cc0050e5973712 enabled/enabled 5 disk - enabled/enabled 6 disk 00c500506dd34085 enabled/enabled 7 disk - enabled/enabled 8 disk - enabled/enabled 9 disk 00c5005045d64085 enabled/enabled 10 disk - enabled/enabled 11 disk - enabled/enabled 12 input 80090a5045e46f06 enabled/enabled 13 input 80090a5045e46f06 enabled/enabled 14 input 80090a5045e46f06 enabled/enabled 15 input 80090a5045e46f06 enabled/enabled 16 virtual 8a090a503d100b17 enabled/enabled 5 0 disk 00c50050c9d54085 enabled/enabled 1 disk - enabled/enabled 2 disk - enabled/enabled 3 disk 00c50050f9d44085 enabled/enabled 4 disk - enabled/enabled 5 disk - enabled/enabled 6 disk 00c5005081d34085 enabled/enabled 7 disk - enabled/enabled 8 disk - enabled/enabled 9 disk 00c500505dd64085 enabled/enabled 10 disk - enabled/enabled 11 disk - enabled/enabled 12 input 80090a5045e46f06 enabled/enabled 13 input 80090a5045e46f06 enabled/enabled 14 input 80090a5045e46f06 enabled/enabled 15 input 80090a5045e46f06 enabled/enabled 16 virtual 8a090a503df00a17 enabled/enabled 85 entries were displayed. cluster1::>
The following example displays expanded information for PHY 0 of drawer 1 in shelf 2.5:
cluster1::> storage shelf drawer show-phy -shelf 2.5 -drawer 1 -phy 0 Shelf: 2.5 Drawer ID: 1 PHY Number: 0 Type: disk Physical ID: 1 SAS Address: 00c5005079183f85 State A: enabled State B: enabled Status A: enabled-12gbs Status B: enabled-12gbs cluster1::>
