storage disk option show
Display a list of disk options
The storage disk option show command displays the settings of the following disk options:
  • Background firmware update
  • Automatic copying of data to a spare disk in the event of a predictive failure
  • Automatic assignment of disks
  • Policy that governs automatic assignment of unowned disks
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
Selects the node that owns the disks. If this parameter is not specified, the command displays information about the disk options on all the nodes.
[-bkg-firmware-update {on|off}] - Background Firmware Update
Selects the disks that match this parameter value.
[-autocopy {on|off}] - Auto Copy
[-autoassign {on|off}] - Auto Assign
Displays the auto assignment status of unowned disks. The default value is on .
[-autoassign-policy {default|bay|shelf|stack}] - Auto Assignment Policy
Selects the disks that match the automatic assignment policy value:
  • Default
  • Stack/loop
  • Shelf
  • Bay
The following example displays disk-option settings for disks owned by all nodes in the cluster:
cluster1::> storage disk option show
Node           BKg. FW. Upd.  Auto Copy     Auto Assign   Auto Assign Policy
node0          on             on            on      default
node1          on             on            on      stack
node2          on             on            on      bay
node3          on             on            on      bay
4 entries were displayed.
