system script delete
Delete saved CLI session logs
The system script delete command deletes files that contain CLI session records. Use the system script show command to display saved CLI sessions.
-username <text> - Log Owner Username
Use this parameter to specify the name of the user whose CLI session record files are deleted. The default is the username is that of the logged in user.
-filename <text> - Log Filename
Use this parameter to specify the names of CLI session record files to delete.
The following example shows how to delete the files named sessionlog2 and sessionlog3 .
cluster1::> system script delete -filename sessionlog2,sessionlog3
The following example deletes all saved script files.
cluster1::> system script delete *
